Salta al contenuto principale
PCI Express Cards (Early 2008)
Cosa ti serve
  1. PCI Express Cards (Early 2008), Opening the Computer (2006-2008): passo 1, immagine 1 di 2 PCI Express Cards (Early 2008), Opening the Computer (2006-2008): passo 1, immagine 2 di 2
    • Shut down the computer.
    • Warning: Always shut down the computer before opening it to avoid damaging its internal components or the components you are installing. Do not open the computer or attempt to install items inside it while it is on.
    • Wait 5 to 10 minutes to allow the computer’s internal components to cool.
    • Warning: After you shut down the system, the internal components can be very hot. You must let the computer cool down before continuing.
    • Unplug all external cables from the computer except the power cord.
    • Touch the metal PCI access covers on the back of the computer to discharge any static electricity from your body.
    • Unplug the power cord.
    • Put on an ESD wrist strap.
    Updated to reflect same procedure for all models in range
    DavidM - Replica
  2. PCI Express Cards (Early 2008): passo 2, immagine 1 di 1
    • 1) Hold the side access panel and lift the latch on the back of the computer.
    • Warning: The edges of the access panel and the enclosure can be sharp. Be very careful when handling them.
    • 2) Remove the access panel and place it on a flat surface covered by a soft, clean cloth.
    • Replacement Note: Make sure the latch is in the up position before replacing the access panel. If the latch is down, the access panel will not seat correctly in the enclosure.
    Is this the actual width of the drive or the internal layout.
    Stephen - Replica
  3. PCI Express Cards (Early 2008), Graphic Card for Mac Pro (2006-2008): passo 3, immagine 1 di 2 PCI Express Cards (Early 2008), Graphic Card for Mac Pro (2006-2008): passo 3, immagine 2 di 2
    • This procedure explains how to remove a standard card and a card that includes a booster cable. Before you can remove either type of card, however, you must first loosen the two captive screws that secure the PCI bracket to the enclosure and remove the bracket.
  4. PCI Express Cards (Early 2008): passo 4, immagine 1 di 1
    • Handle the card only by the edges.Do not touch its connectors or any of the components.Lift the card straight out from the connector to remove it, and insert it straight into the connector to install it.Do not rock the card from side to side and don’t force the card into the slot.Once the replacement card is installed, pull on it gently to check.
    • 1) Release the small locking clip at the front of the card’s logic board connector by pushing the clip up toward the media shelf.
    • 2) Holding the card by the top corners, pull up the card and remove it from its expansion slot.
  5. PCI Express Cards (Early 2008), Card with Booster Cable: passo 5, immagine 1 di 2 PCI Express Cards (Early 2008), Card with Booster Cable: passo 5, immagine 2 di 2
    • Some graphics cards require either one or two booster cables connecting the card to the auxillary power connectors on the logic board.
    • The graphics card NVIDIA GeForce 8800 GT requires one booster cable; the graphics card NVIDIA Quadro FX 5600 requires two booster cables.
    • Disconnect the booster cable(s) from the logic board.
    • Release the small locking clip at the front of the card’s logic board connector by pushing the clip up toward the media shelf.
    • Holding the card by the top corners, gently pull up the card and remove it from its expansion slot.
    • If you are replacing a booster cable with a new one, disconnect the cable from the card.
  6. PCI Express Cards (Early 2008): passo 6, immagine 1 di 1
    • Replacement Note for Card Using One Booster Cable: Be sure to connect the card’s booster cable to the correct auxillary power connector on the logic board. Connect the booster cable for a card in PCI slot 1 to the lower connector. Connect the booster cable for a card in PCI slot 2 to the upper connector.
    • Replacement Note for Card Using Two Booster Cables: Connect both cables to the two auxillary power connectors.
    Estoy buscando el cable de alimentación de la tarjeta gráfica, pero no lo consigo alguna idea de dónde lo podría conseguir?
    Videos premium - Replica
  7. PCI Express Cards (Early 2008), PCI Express Cards (Early 2008): passo 7, immagine 1 di 1
    • The procedure to remove the graphic cards is the same for PCI Express Cards for exception of minor card differences.
    • Important: Combined maximum power consumption for all four PCI Express slots must not exceed 300 W.
Conclusione
Altre 11 persone hanno completato questa guida.
Joshua Byrne
Membro da: 05/03/13
7.725 Reputazione
10 Guide realizzate
2 Commenti
Wish I had seen this guide a few years ago when I was upgrading my Mac. Would have saved me a few steps.
Travis Potter - Replica
I have a used MacPro 2008. No screws on the PCI boards. Can I purchase them from you? I need at least3-4 of them. thanks.
Jon Bonci - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 64
Tutti i Tempi: 9,560
