Salta al contenuto principale
Ozeri Pronto ZK14-S Button Replacement
Cosa ti serve
  1. Ozeri Pronto ZK14-S Button Replacement, Panel Removal: passo 1, immagine 1 di 2 Ozeri Pronto ZK14-S Button Replacement, Panel Removal: passo 1, immagine 2 di 2
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S Button Replacement: passo 2, immagine 1 di 1
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S Button Replacement: passo 3, immagine 1 di 1
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S Button Replacement: passo 4, immagine 1 di 2 Ozeri Pronto ZK14-S Button Replacement: passo 4, immagine 2 di 2
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S Button Replacement: passo 5, immagine 1 di 2 Ozeri Pronto ZK14-S Button Replacement: passo 5, immagine 2 di 2
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S Button Replacement: passo 6, immagine 1 di 1
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S Button Replacement: passo 7, immagine 1 di 1
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S Button Replacement: passo 8, immagine 1 di 1
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S Button Replacement: passo 9, immagine 1 di 2 Ozeri Pronto ZK14-S Button Replacement: passo 9, immagine 2 di 2
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
  10. Ozeri Pronto ZK14-S Button Replacement, Button: passo 10, immagine 1 di 2 Ozeri Pronto ZK14-S Button Replacement, Button: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Compra
    • Using a 2.0 Flathead screwdriver, remove the two 7.34 mm screws on the smaller motherboards.
  11. Ozeri Pronto ZK14-S Button Replacement: passo 11, immagine 1 di 2 Ozeri Pronto ZK14-S Button Replacement: passo 11, immagine 2 di 2
    • Desolder the four posts in the center of the motherboard.
    • Caution: The tip of the soldering iron will be very hot
  12. Ozeri Pronto ZK14-S Button Replacement: passo 12, immagine 1 di 2 Ozeri Pronto ZK14-S Button Replacement: passo 12, immagine 2 di 2
    • Desolder the two clips in the center of the motherboard.
    • Repeat steps 13 and 14 to remove the other button from its motherboard.
Conclusione
USF Tampa, Team 1-4, Leahy Fall 2015 Membro di USF Tampa, Team 1-4, Leahy Fall 2015
USFT-LEAHY-F15S1G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 822
