Salta al contenuto principale
Oster 6329 Power Cord Replacement
Cosa ti serve
  1. Oster 6329 Power Cord Replacement, Outer Shell Removal: passo 1, immagine 1 di 2 Oster 6329 Power Cord Replacement, Outer Shell Removal: passo 1, immagine 2 di 2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Power Cord Replacement: passo 2, immagine 1 di 1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Power Cord Replacement: passo 3, immagine 1 di 1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Power Cord Replacement: passo 4, immagine 1 di 2 Oster 6329 Power Cord Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Power Cord Replacement: passo 5, immagine 1 di 2 Oster 6329 Power Cord Replacement: passo 5, immagine 2 di 2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Oster 6329 Power Cord Replacement, Power Cord: passo 6, immagine 1 di 1
    • Using a flat-head screwdriver, pry the power cord from the base of the toaster.
  7. Oster 6329 Power Cord Replacement: passo 7, immagine 1 di 1
    • Using a flat-head screwdriver, pry the white wire from the base.
  8. Oster 6329 Power Cord Replacement: passo 8, immagine 1 di 1
    • Locate the circuit board at the front of the toaster where the power cord and white wire meet.
    • Pull the circuit board up and out to free the circuit board from the body of the toaster.
    • It is tightly fit and may take moderate force to remove.
  9. Oster 6329 Power Cord Replacement: passo 9, immagine 1 di 2 Oster 6329 Power Cord Replacement: passo 9, immagine 2 di 2
    • Desolder the power cord from the circuit board at the locations show in the diagram.
    • For soldering instructions see the iFixit Soldering Guide.
    • The wires should be free from board when un-soldering is complete.
  10. Oster 6329 Power Cord Replacement: passo 10, immagine 1 di 2 Oster 6329 Power Cord Replacement: passo 10, immagine 2 di 2
    • Unscrew the two 1.5cm Phillips-head screws at the back of the toaster that are holding the power cord in place to remove the retaining clip.
    • Remove the plastic retaining clip that is holding the cord in place.
  11. Oster 6329 Power Cord Replacement: passo 11, immagine 1 di 2 Oster 6329 Power Cord Replacement: passo 11, immagine 2 di 2
    • Untie the knot in the power cord.
  12. Oster 6329 Power Cord Replacement: passo 12, immagine 1 di 1
    • Pull the cord from the base to remove the cable.
Conclusione
Cal Poly, Team 13-15, Regan Winter 2014 Membro di Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 901
