Introduzione
This guide will walk you through replacing the speaker. Be careful as this guide will have you using the solder iron. You may need this guide if the Orbo Jr. speaker has crackling noises or no noise is coming from the speaker.
Cosa ti serve
Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
Positive and Negative battery terminals.
Unsolder the positive and negative speaker wires from the connection on the motherboard.
