Salta al contenuto principale
Oral-B Black 7000 Motor Replacement
Cosa ti serve
  1. Oral-B Black 7000 Motor Replacement, Induction Charging Coil: passo 1, immagine 1 di 3 Oral-B Black 7000 Motor Replacement, Induction Charging Coil: passo 1, immagine 2 di 3 Oral-B Black 7000 Motor Replacement, Induction Charging Coil: passo 1, immagine 3 di 3
    • Use the charging station to remove the a small plastic plug from the end of the toothbrush by inserting the charging station into the end insert and twisting counter-clockwise by 90 degrees.
  2. Oral-B Black 7000 Motor Replacement: passo 2, immagine 1 di 1
    • Remove the end cap from the bottom of the toothbrush by prying it off with a spudger.
  3. Oral-B Black 7000 Motor Replacement: passo 3, immagine 1 di 1
    • Remove the top cap by using a spudger to pry the plastic ring off of the toothbrush frame.
  4. Oral-B Black 7000 Motor Replacement: passo 4, immagine 1 di 2 Oral-B Black 7000 Motor Replacement: passo 4, immagine 2 di 2
    • Use a spudger to loosen the two plastic tabs next to the induction coil that secure the internal assembly to the frame.
    • Push on the rotating head in order to pop the assembly out of the black plastic casing.
    • You can also use a spudger to leverage the assembly out, but this may break the copper wire connected to the induction coil, so be careful.
  5. Oral-B Black 7000 Motor Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Unwrap the ends of the wires from the white plastic pegs using a pair of tweezers.
    • Each wire end is wrapped around the peg 3-4 times.
  6. Oral-B Black 7000 Motor Replacement: passo 6, immagine 1 di 1
    • Melt the solder at the two pads on either side of the top of the motherboard. This will require a high heat soldering iron. Remove the wire from the solder pads using tweezers once the solder melts.
  7. Oral-B Black 7000 Motor Replacement: passo 7, immagine 1 di 1
    • Remove the induction coil by pulling the plastic tabs out of their keepers.
    • A spudger can be used to remove the plastic tabs from their keepers if neccessary.
  8. Oral-B Black 7000 Motor Replacement, Motor: passo 8, immagine 1 di 1
    • Desolder the red LED wires from the solder pads near the rotating head of the device.
    • These wires are quite delicate, so be sure the solder is fully melted before attempting to pull the wire out.
  9. Oral-B Black 7000 Motor Replacement: passo 9, immagine 1 di 2 Oral-B Black 7000 Motor Replacement: passo 9, immagine 2 di 2
    Compra
    • Use a pair of tweezers to remove the plastic housing and the LED from the device.
  10. Oral-B Black 7000 Motor Replacement: passo 10, immagine 1 di 1
    • Remove the spring from the housing using a nylon spudger.
    • Use a nylon spudger rather than a metal one in order to minimize the risk of puncturing the battery.
  11. Oral-B Black 7000 Motor Replacement: passo 11, immagine 1 di 3 Oral-B Black 7000 Motor Replacement: passo 11, immagine 2 di 3 Oral-B Black 7000 Motor Replacement: passo 11, immagine 3 di 3
    • Remove the motor housing from the plastic casing. This can be accomplished by using the nylon spudger to pry the motor housing out of the supporting structures.
    • The physical parts holding onto the motor are plastic knobs built into the plastic casing. Any manipulation done to the casing to remove the motor should be done within reason so that the casing is able to be reused.
  12. Oral-B Black 7000 Motor Replacement: passo 12, immagine 1 di 2 Oral-B Black 7000 Motor Replacement: passo 12, immagine 2 di 2
    • Desolder the motor terminals from the motherboard and remove the motor assembly.
Conclusione
IUPUI, Team S1-G1, Harley Fall 2017 Membro di IUPUI, Team S1-G1, Harley Fall 2017
IUPUI-HARLEY-F17S1G1
3 Membri
16 Guide realizzate
4 Commenti
Hallo,
Super-Anleitung. Kannst Du verraten, was für einen Motor man zur Austausch benötigt?
Spannung, Leistung, Umdrehungen, Maße, etc.?
Und vielleicht eine Bezugsquelle.
Danke Dir,
Kai
Kai Richter - Replica
How do I know if the motor needs replacing? My battery seems fine. The toothbrush buzzes and I can hear it change modes when I push the mode button, but the head doesn’t swivel. Thanks
Laura - Replica
Die Spule unten muss nicht ab! Woher bekommst du eine Ersatz motor? Im Internet findet man Nichts?!
Hans Wurst - Replica
Vielleicht bei diesem Verkäufer?
VauWeh -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 99
Tutti i Tempi: 4,026
