Introduzione
If you want to access internal components such as the pump or the heater, you have to open the machine. This is shown here.
Cosa ti serve
Remove all attachments such as the water tank, pomace container, brew group and drip tray.
Remove all the coffee beans from the machine.
Slide the cup holder all the way down.
Start to pry off the molded part at the back seam, the catches gradually loosen with a loud crack.
It's a bit tricky to slide the cover over the steam valve knob, you need some strength to do it.
Under the bean container, you'll find the white magnetic contact (reed contact) for the bean container lid. Lift it up and drop it through the opening in the molding.
Lift up the cover.
The two side parts are attached with a few Torx T10 screws, unscrew them:
A screw at the top back
A screw at the top
Four screws on the front
Please, what is the silver thing on the middle?
I opened my machine and it was broken.
You mean the silver band on the front of the machine? That’s sort of like a pull down shade connected to the sliding drip tray support.
Altre 16 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
6 Commenti
Danke. Hat prima funktioniert.
Perfect immer schön positives Feedback zu bekommen
Jawoll! Freut mich! :-)
VauWeh -
