Salta al contenuto principale
Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement
Cosa ti serve
  1. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: passo 1, immagine 1 di 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: passo 1, immagine 2 di 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: passo 2, immagine 1 di 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: passo 2, immagine 2 di 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: passo 2, immagine 3 di 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: passo 3, immagine 1 di 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: passo 3, immagine 2 di 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: passo 3, immagine 3 di 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: passo 4, immagine 1 di 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: passo 4, immagine 2 di 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: passo 4, immagine 3 di 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Auxiliary Port: passo 5, immagine 1 di 1
    • With your solderwick and soldering iron, remove the solder at each point, and gently pull the 3.5mm port away from the motherboard with your tweezers.
    • For more information on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 27
Tutti i Tempi: 253
