Salta al contenuto principale
OneLink Safe and Sound Bluetooth Module Replacement
Cosa ti serve
  1. OneLink Safe and Sound Bluetooth Module Replacement, Cover: passo 1, immagine 1 di 2 OneLink Safe and Sound Bluetooth Module Replacement, Cover: passo 1, immagine 2 di 2
    • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
    • Remove plastic rim.
    Chiedi a FixBot
  2. OneLink Safe and Sound Bluetooth Module Replacement: passo 2, immagine 1 di 2 OneLink Safe and Sound Bluetooth Module Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
    Chiedi a FixBot
  3. OneLink Safe and Sound Bluetooth Module Replacement: passo 3, immagine 1 di 2 OneLink Safe and Sound Bluetooth Module Replacement: passo 3, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
    • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
    Chiedi a FixBot
  4. OneLink Safe and Sound Bluetooth Module Replacement: passo 4, immagine 1 di 1
    • Use tweezers to unplug the speaker cable from the motherboard.
    Chiedi a FixBot
  5. OneLink Safe and Sound Bluetooth Module Replacement: passo 5, immagine 1 di 2 OneLink Safe and Sound Bluetooth Module Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to remove the microphone connection from the motherboard.
    • Remove the top of the device.
    Chiedi a FixBot
  6. OneLink Safe and Sound Bluetooth Module Replacement, Bluetooth Module: passo 6, immagine 1 di 1
    • Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
    Chiedi a FixBot
  7. OneLink Safe and Sound Bluetooth Module Replacement: passo 7, immagine 1 di 2 OneLink Safe and Sound Bluetooth Module Replacement: passo 7, immagine 2 di 2
    • Lift the Bluetooth module off of the daughterboard.
    • Lift it straight up to avoid bending the delicate pins that connect the Bluetooth module to the board.
    Chiedi a FixBot
Conclusione
UMass Dartmouth, Team 2-2, Petersen Fall 2022 Membro di UMass Dartmouth, Team 2-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G2
3 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 375
