Salta al contenuto principale
OnHub OnHub Antenna Array Replacement
Cosa ti serve
  1. OnHub OnHub Antenna Array Replacement, Speaker Grille: passo 1, immagine 1 di 2 OnHub OnHub Antenna Array Replacement, Speaker Grille: passo 1, immagine 2 di 2
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
  2. OnHub OnHub Antenna Array Replacement: passo 2, immagine 1 di 1
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
  3. OnHub OnHub Antenna Array Replacement: passo 3, immagine 1 di 2 OnHub OnHub Antenna Array Replacement: passo 3, immagine 2 di 2
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
  4. OnHub OnHub Antenna Array Replacement, Congestion-sensing Antenna: passo 4, immagine 1 di 2 OnHub OnHub Antenna Array Replacement, Congestion-sensing Antenna: passo 4, immagine 2 di 2
    • Remove the wire connection to the antenna by soldering it off.
    • For help with soldering and de-soldering check out the iFixit Soldering Guide
  5. OnHub OnHub Antenna Array Replacement, Outer Casing: passo 5, immagine 1 di 2 OnHub OnHub Antenna Array Replacement, Outer Casing: passo 5, immagine 2 di 2
    • You must remove the plastic cover found just above the speaker.
    • Wedge the plastic opening tool under the cover and apply pressure in an upward direction.
    • There are four clips that you are removing. When disengaged, these clips will make a snapping noise.
    • Though the snapping noise is normal, take care not to break these clips.
  6. OnHub OnHub Antenna Array Replacement: passo 6, immagine 1 di 1
    • Upon removing the cover, four screws and the speaker housing will be exposed.
    • Unscrew the four 12mm screws using a #1 Phillips head screwdriver.
    • This unlocks the speaker housing and antenna array from the casing.
  7. OnHub OnHub Antenna Array Replacement: passo 7, immagine 1 di 2 OnHub OnHub Antenna Array Replacement: passo 7, immagine 2 di 2
    • On the bottom of the OnHub is two screws holding the casing to the base.
    • To access these screws, you must remove the rubber pad that is glued to the base.
    • To remove the pad, slide a metal spudger under the edge of the pad. Pry the pad away from the base, removing the glue.
    • Once the pad is pulled up enough to grab, peel it the rest of the way exposing the screws.
    • The rubber pad is thin and fragile; be careful not to tear when removing.
  8. OnHub OnHub Antenna Array Replacement: passo 8, immagine 1 di 1
    • Remove the two 12mm screws under the base of the OnHub by using a #1 Phillips head screwdriver.
  9. OnHub OnHub Antenna Array Replacement: passo 9, immagine 1 di 2 OnHub OnHub Antenna Array Replacement: passo 9, immagine 2 di 2
    • Once the two screws are removed from the base, it is time to split the casing apart.
    • It is okay if a couple clips break. It will still hold together with a few remaining.
    • Wedge a spudger between the two casing halves, and pry the clips apart starting from the top
    • There are three hooking style clips in total.
  10. OnHub OnHub Antenna Array Replacement: passo 10, immagine 1 di 1
    • Once unclipped, you can slide the two casing halves apart, and remove the casing.
  11. OnHub OnHub Antenna Array Replacement, Speaker: passo 11, immagine 1 di 2 OnHub OnHub Antenna Array Replacement, Speaker: passo 11, immagine 2 di 2
    • Underneath the speaker is an intertwined black and white wire.
    • Disconnect the wire from its connection to the motherboard.
  12. OnHub OnHub Antenna Array Replacement: passo 12, immagine 1 di 1
    • The speaker should now easily come off with a firm grip on the OnHub device and pull.
  13. OnHub OnHub Antenna Array Replacement, OnHub Antenna Array: passo 13, immagine 1 di 1
    • There is a black, horizontal brace covering 12 wire connections.
    • Remove the brace, held by two screws
  14. OnHub OnHub Antenna Array Replacement: passo 14, immagine 1 di 2 OnHub OnHub Antenna Array Replacement: passo 14, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Make a note of each wire's position and color, so it will be easier to reconnect later.
    • Using tweezers, gently disconnect each of the 12 wire connections, attached to the top of the motherboard.
    • Be careful when removing the gold connectors as they are easily bent.
    • The connection points can be bent back if not damaged too badly.
  15. OnHub OnHub Antenna Array Replacement: passo 15, immagine 1 di 1
    • Make sure to carefully pull the tape style wire furthest to the left that is held by glue.
Conclusione
Altre 3 persone hanno completato questa guida.
Mahir Abdella
Membro da: 02/10/16
331 Reputazione
2 Guide realizzate
USF Tampa, Team 3-3, Sullivan Spring 2016 Membro di USF Tampa, Team 3-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G3
3 Membri
10 Guide realizzate
1Commento della guida
That’s not a “tape-style wire”, that’s a ZIF flex cable! (ZIF is short for Zero Insertion Force)
To unplug that flex cable (which connects the LEDs to the main board) flip the little black bit at the other side of the connector up, then pull out the cable.
Jefferson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 670
