Salta al contenuto principale
Olympus C-765 LCD Screen Replacement
Cosa ti serve
  1. Olympus C-765 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Olympus C-765 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Olympus C-765 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Remove all the screws using your Phillips #00 holding the back plate in place. This includes:
    • On the Back: Unscrew the 4mm screw to the right of the viewfinder.
    • On the Bottom:
    • Unscrew the 3mm screw in the top left corner.
    • Unscrew the four 3mm screws under the battery cover.
    • On the Right Side: Unscrew the one 3mm screw holding the right-side panel.
    • On the Left Side: Unscrew the two 2mm screws holding the left-side panel.
  2. Olympus C-765 LCD Screen Replacement: passo 2, immagine 1 di 2 Olympus C-765 LCD Screen Replacement: passo 2, immagine 2 di 2
    • After you remove the back cover:
    • Gently pull the two ribbon cables out of their sockets.
    • Gently disconnect the white cable.
  3. Olympus C-765 LCD Screen Replacement: passo 3, immagine 1 di 3 Olympus C-765 LCD Screen Replacement: passo 3, immagine 2 di 3 Olympus C-765 LCD Screen Replacement: passo 3, immagine 3 di 3
    • Peel the black tape off the back of the LCD.
    • Using the Phillips #00 remove the four 3mm screws on the LCD bracket.
    • Remove the two 2mm screws from the top of the bracket.
    • Use a spudger to pop the LCD screen out of the camera’s backplate.
    • When the bracket comes off, the buttons from the top section may fall out of place. If this happens then put them back in the position they were in.
Conclusione
Altre 2 persone hanno completato questa guida.
Mason Morgan
Membro da: 04/05/11
118 Reputazione
6 Guide realizzate
Cal Poly, Team 12-33, Maness Spring 2011 Membro di Cal Poly, Team 12-33, Maness Spring 2011
CPSU-MANESS-S11S12G33
3 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 3,145
