Salta al contenuto principale
Oculus Rift Control Box Motherboard Replacement
Cosa ti serve
  1. Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: passo 1, immagine 1 di 3 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: passo 1, immagine 2 di 3 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: passo 1, immagine 3 di 3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Oculus Rift Control Box Motherboard Replacement: passo 2, immagine 1 di 3 Oculus Rift Control Box Motherboard Replacement: passo 2, immagine 2 di 3 Oculus Rift Control Box Motherboard Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
  3. Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: passo 3, immagine 1 di 3 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: passo 3, immagine 2 di 3 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: passo 3, immagine 3 di 3
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
  4. Oculus Rift Control Box Motherboard Replacement: passo 4, immagine 1 di 3 Oculus Rift Control Box Motherboard Replacement: passo 4, immagine 2 di 3 Oculus Rift Control Box Motherboard Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
Conclusione
Audrey Chan
Membro da: 01/12/15
201 Reputazione
2 Guide realizzate
Cal Poly, Team 70-5, Forte Winter 2015 Membro di Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,236
