Introduzione
The Micro USB Port is for charging your tablet. If damage had ever occurred to it, you may find it loose, or not holding your charging cable.
Cosa ti serve
Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
Using the blue plastic opening tool, place the lip of the tool underneath the battery as seen in the photo.
Attrezzo utilizzato in questo passaggio:Tweezers$3.99
Use the angled tweezers to disconnect the black power cable from the mother board. The Cable should pop up from its slot when pulled.
While using the black plastic spudger tool, slowly lift the tape with your fingers and hold the wires down with the tool.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Carefully remove the audio input films for each speaker from their respective ZIF (zero insertion force) connectors. These are the paper thin ribbons that have orange stripes along them.
Pull up the white latch on the ZIF connector, which will release the film and allow you to pull it out with tweezers.
Repeat this for both speakers.
Using the tweezers or your fingers lift the remaining black wires from the motherboard.
Altre 5 persone hanno completato questa guida.
12Commenti sulla guida
Where I can find a micro UBS port for Nvidia shield tablet ?
Micro usb -B, Amazon.
it's a standard form factor, just check ebay
It might be cheaper to solder a new one. I would compare prices, and decide if the price is worth soldering. If you want experience in soldering, go the solder route. Refining this skill will help later if you need to solder anything else.
