Salta al contenuto principale
Nvidia Shield Battery Assembly Replacement
Cosa ti serve
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: passo 1, immagine 1 di 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: passo 1, immagine 2 di 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: passo 1, immagine 3 di 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: passo 2, immagine 1 di 2 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: passo 2, immagine 2 di 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: passo 3, immagine 1 di 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: passo 3, immagine 2 di 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: passo 3, immagine 3 di 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: passo 4, immagine 1 di 1
    • Pull the battery apparatus out once all cables are removed.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 1-1, Hickman Fall 2014 Membro di USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membri
18 Guide realizzate
4 Commenti
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Replica
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - Replica
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - Replica
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 73
Tutti i Tempi: 5,749
