Salta al contenuto principale
Nook Simple Touch with GlowLight Motherboard Replacement
Cosa ti serve
  1. Nook Simple Touch with GlowLight Motherboard Replacement, Power Button: passo 1, immagine 1 di 1
    • Place the Nook with the screen facing down.
  2. Nook Simple Touch with GlowLight Motherboard Replacement: passo 2, immagine 1 di 1
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
  3. Nook Simple Touch with GlowLight Motherboard Replacement: passo 3, immagine 1 di 1
    • Using your fingers, gently remove the power button.
  4. Nook Simple Touch with GlowLight Motherboard Replacement, Back Cover: passo 4, immagine 1 di 1
    • Remove the single screw using a T4 Torx screwdriver.
  5. Nook Simple Touch with GlowLight Motherboard Replacement: passo 5, immagine 1 di 1
    • Slide the back cover down towards you in the direction of the charging port.
  6. Nook Simple Touch with GlowLight Motherboard Replacement, Battery: passo 6, immagine 1 di 2 Nook Simple Touch with GlowLight Motherboard Replacement, Battery: passo 6, immagine 2 di 2
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
  7. Nook Simple Touch with GlowLight Motherboard Replacement, Motherboard: passo 7, immagine 1 di 1
    • Remove eleven screws from the motherboard using the T4 screwdriver.
  8. Nook Simple Touch with GlowLight Motherboard Replacement: passo 8, immagine 1 di 3 Nook Simple Touch with GlowLight Motherboard Replacement: passo 8, immagine 2 di 3 Nook Simple Touch with GlowLight Motherboard Replacement: passo 8, immagine 3 di 3
    • Disconnect the orange ribbon cable from the motherboard.
    • Using your fingers, gently lift the motherboard from the display.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 88
