Salta al contenuto principale
Nook BNRV300 Power Button Replacement
Cosa ti serve
  1. Nook BNRV300 Power Button Replacement, Power Button: passo 1, immagine 1 di 3 Nook BNRV300 Power Button Replacement, Power Button: passo 1, immagine 2 di 3 Nook BNRV300 Power Button Replacement, Power Button: passo 1, immagine 3 di 3
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
  2. Nook BNRV300 Power Button Replacement: passo 2, immagine 1 di 1
    • Using your fingers, take off the power button.
Conclusione
2 Commenti
My power button is not responding. Presumably I have to let the power drain because it won't shut off. Do i replace the button or the sensor beneath it?
Lydia Rice - Replica
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 813
