Salta al contenuto principale
Nook BNRV300 Display Replacement
Cosa ti serve
  1. Nook BNRV300 Display Replacement, Power Button: passo 1, immagine 1 di 3 Nook BNRV300 Display Replacement, Power Button: passo 1, immagine 2 di 3 Nook BNRV300 Display Replacement, Power Button: passo 1, immagine 3 di 3
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
  2. Nook BNRV300 Display Replacement: passo 2, immagine 1 di 1
    • Using your fingers, take off the power button.
  3. Nook BNRV300 Display Replacement, Back Cover: passo 3, immagine 1 di 3 Nook BNRV300 Display Replacement, Back Cover: passo 3, immagine 2 di 3 Nook BNRV300 Display Replacement, Back Cover: passo 3, immagine 3 di 3
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
  4. Nook BNRV300 Display Replacement: passo 4, immagine 1 di 1
    • Slide the back cover down towards the USB port to release it. The pictures show the case being prised open but this should not be necessary.
  5. Nook BNRV300 Display Replacement: passo 5, immagine 1 di 3 Nook BNRV300 Display Replacement: passo 5, immagine 2 di 3 Nook BNRV300 Display Replacement: passo 5, immagine 3 di 3
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
  6. Nook BNRV300 Display Replacement: passo 6, immagine 1 di 2 Nook BNRV300 Display Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
  7. Nook BNRV300 Display Replacement, Motherboard: passo 7, immagine 1 di 2 Nook BNRV300 Display Replacement, Motherboard: passo 7, immagine 2 di 2
    • Use an anti-static mat to prevent electric shock from damaging the motherboard and its components. Be careful when using metal tools on your device.
    • Using a T5 Torx screwdriver, remove the eleven 3mm screws.
  8. Nook BNRV300 Display Replacement: passo 8, immagine 1 di 3 Nook BNRV300 Display Replacement: passo 8, immagine 2 di 3 Nook BNRV300 Display Replacement: passo 8, immagine 3 di 3
    • Place the spudger through the loop of the display cable. Lift the tool up, which will unhook the display cable.
    • Do not put force on the motherboard with the spudger. This could damage components on the motherboard.
    • Using your fingers, lift up the display cable.
  9. Nook BNRV300 Display Replacement: passo 9, immagine 1 di 1
    • Using your fingers, gently lift the motherboard from the display.
  10. Nook BNRV300 Display Replacement, Display: passo 10, immagine 1 di 3 Nook BNRV300 Display Replacement, Display: passo 10, immagine 2 di 3 Nook BNRV300 Display Replacement, Display: passo 10, immagine 3 di 3
    • Insert a nylon spudger between the display's metal backing and the front cover plastic.
    • Gently pry the display away from the front cover by moving the spudger up and down.
    • During reassembly, align the small black plastic peg at the bottom right of the plastic frame with the inner hole at the bottom right of the metal display backing.
  11. Nook BNRV300 Display Replacement: passo 11, immagine 1 di 2 Nook BNRV300 Display Replacement: passo 11, immagine 2 di 2
    • Press down on the fastener tab with your finger.
  12. Nook BNRV300 Display Replacement: passo 12, immagine 1 di 2 Nook BNRV300 Display Replacement: passo 12, immagine 2 di 2
    • The display cracks very easily. If this happens, there will be glass shards that could potentially cause injury. You may want to wear protection for hands and eyes while completing this step.
    • Insert a nylon spudger between the plastic frame on the display and the metal casing on the display.
    • Gently pry the display away from the plastic frame. Place the display on a hard, flat surface to support it when prying it off the metal backing. The screen may crack anyway.
Conclusione
Altre 2 persone hanno completato questa guida.
5 Commenti
Was all good till I got here:
The display was glued to the metal backing. Needs something to heat up the adhesive in order to remove it.
Joseph W Charpentier - Replica
Hi. What display model should I look for? Is this one ED060SC7 good?
pogo79 - Replica
I'm looking in the Aliexp... store and I don't know what display to choose .
pogo79 - Replica
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Replica
Appreciate the feedback!
Emily Tracy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 2,498
