Introduzione
The battery is one of the most common components in need of replacement. This guide contains instructions for removing the 3.7 V lithium-ion polymer battery in the Nook BNRV300 device. This device is also called the “Nook Simple Touch.”
Without a properly-functioning battery, your Nook will not operate. First try troubleshooting your Nook device using these guides if your Nook does not power on, or your Nook will not hold a charge. If your Nook device still fails to operate properly, then follow this Nook BNRV300 Battery Replacement Guide.
Warning: If the battery is swelling, causing discoloration, or smelling bad, removing it may be dangerous. If you suspect your battery is damaged, see this helpful guide for what to do with a swollen battery.
Cosa ti serve
Turn the Nook over to find the power button along the back upper edge.
Wedge the spudger between the top of the power button and the upper edge of the device.
Push the tool down to pry the button up and off.
Peel off the white sticker that is covering the screw head.
Remove the one 2mm-long screw using a size T5 Torx screwdriver.
Insert a nylon spudger beneath the clear plastic adhesive holding the battery to the back cover.
Work around the battery, peeling up all of the adhesive.
Altre 3 persone hanno completato questa guida.
