Salta al contenuto principale
Nobis NB07 Speaker Replacement
Cosa ti serve
  1. Nobis NB07 Speaker Replacement, Opening the case: passo 1, immagine 1 di 1
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Speaker Replacement: passo 2, immagine 1 di 3 Nobis NB07 Speaker Replacement: passo 2, immagine 2 di 3 Nobis NB07 Speaker Replacement: passo 2, immagine 3 di 3
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Speaker Replacement, Replacing the battery: passo 3, immagine 1 di 3 Nobis NB07 Speaker Replacement, Replacing the battery: passo 3, immagine 2 di 3 Nobis NB07 Speaker Replacement, Replacing the battery: passo 3, immagine 3 di 3
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Speaker Replacement: passo 4, immagine 1 di 3 Nobis NB07 Speaker Replacement: passo 4, immagine 2 di 3 Nobis NB07 Speaker Replacement: passo 4, immagine 3 di 3
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Speaker Replacement: passo 5, immagine 1 di 1
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Speaker Replacement: passo 6, immagine 1 di 2 Nobis NB07 Speaker Replacement: passo 6, immagine 2 di 2
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Nobis NB07 Speaker Replacement, Removing the speaker: passo 7, immagine 1 di 3 Nobis NB07 Speaker Replacement, Removing the speaker: passo 7, immagine 2 di 3 Nobis NB07 Speaker Replacement, Removing the speaker: passo 7, immagine 3 di 3
    • Remove the tape holding the speaker in its socket.
  8. Nobis NB07 Speaker Replacement: passo 8, immagine 1 di 2 Nobis NB07 Speaker Replacement: passo 8, immagine 2 di 2
    • After you remove the tape, remove the speaker from its socket. You can place the speaker on one side of the tablet to have more freedom.
    • Look for the place where the speaker's cables meet with the motherboard.
    • Annotate where which color goes to make the reassembly easier.
  9. Nobis NB07 Speaker Replacement: passo 9, immagine 1 di 2 Nobis NB07 Speaker Replacement: passo 9, immagine 2 di 2
    • Use a soldering iron to desolder the cables and extract the solder using a desoldering braid.
    • You can now remove the speaker.
Conclusione
USF Tampa, Team 5-5, Brown Winter 2015 Membro di USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Membri
10 Guide realizzate
2 Commenti
How can I restore the memory on these tablets - were having problems with this tablet please help us
annievvtait07 - Replica
This is my favourite online game mahjong games online i have some time play.
conor mcgregor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 234
