Salta al contenuto principale
Nobis NB07 Microphone Replacement
Cosa ti serve
  1. Nobis NB07 Microphone Replacement, Opening the case: passo 1, immagine 1 di 1
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Microphone Replacement: passo 2, immagine 1 di 3 Nobis NB07 Microphone Replacement: passo 2, immagine 2 di 3 Nobis NB07 Microphone Replacement: passo 2, immagine 3 di 3
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Microphone Replacement, Replacing the battery: passo 3, immagine 1 di 3 Nobis NB07 Microphone Replacement, Replacing the battery: passo 3, immagine 2 di 3 Nobis NB07 Microphone Replacement, Replacing the battery: passo 3, immagine 3 di 3
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Microphone Replacement: passo 4, immagine 1 di 3 Nobis NB07 Microphone Replacement: passo 4, immagine 2 di 3 Nobis NB07 Microphone Replacement: passo 4, immagine 3 di 3
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Microphone Replacement: passo 5, immagine 1 di 1
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Microphone Replacement: passo 6, immagine 1 di 2 Nobis NB07 Microphone Replacement: passo 6, immagine 2 di 2
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Nobis NB07 Microphone Replacement, Removing the cameras: passo 7, immagine 1 di 3 Nobis NB07 Microphone Replacement, Removing the cameras: passo 7, immagine 2 di 3 Nobis NB07 Microphone Replacement, Removing the cameras: passo 7, immagine 3 di 3
    • Remove the black tape covering the cameras power cable.
  8. Nobis NB07 Microphone Replacement: passo 8, immagine 1 di 2 Nobis NB07 Microphone Replacement: passo 8, immagine 2 di 2
    • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
  9. Nobis NB07 Microphone Replacement: passo 9, immagine 1 di 3 Nobis NB07 Microphone Replacement: passo 9, immagine 2 di 3 Nobis NB07 Microphone Replacement: passo 9, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
    • Using tweezers, carefully grab the front camera and twist slowly.
    • The camera should release easily, do not twist too hard.
    • You can now remove the cameras.
  10. Nobis NB07 Microphone Replacement, Removing the microphone: passo 10, immagine 1 di 1
    • Locate the microphone's cables in front of the cameras' ZIF connector.
  11. Nobis NB07 Microphone Replacement: passo 11, immagine 1 di 1
  12. Nobis NB07 Microphone Replacement: passo 12, immagine 1 di 2 Nobis NB07 Microphone Replacement: passo 12, immagine 2 di 2
    Compra
    • Use the pointy end of the tweezers to retrieve the microphone from its socket.
    • You can now remove the microphone.
Conclusione
USF Tampa, Team 5-5, Brown Winter 2015 Membro di USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 152
