Introduzione
To complete this guide, you will need to disassemble your tablet and use a soldering iron to replace the battery. The battery is removed first in most cases, even if you are trying to remove other components.
Cosa ti serve
Look towards the topside of the tablet, where the power button is located.
Insert a plastic opening tool in the crack between the two parts of the case.
Move it gently back and forth to open the case.
Altre 3 persone hanno completato questa guida.
1Commento della guida
where do you find that battery? tried searching by the numbers on it and nothing
