Introduzione
This instruction guide is for a 2011 Nintendo Wii that has a broken or jammed DVD drive. You will know of your DVD drive is broken if you cannot get your game disc in or out of the game console. As your Wii becomes older, it is likely that it can become broken. If your DVD drive becomes jammed or broken, follow these instructions to fix the problem. There are no special requirements, you just need your console and this should be a quick and easy fix. If you are having trouble, check out the troubleshooting page.
Cosa ti serve
Follow Nintendo Wii 2011 Outer Case Removal/Dissassemby up to step 14.
Begin this guide on the metal casing side of the DVD drive.
Steps 2-6 of this guide will walk you through attempting to move/adjust components of the drive that may have become jammed in place.
Altre 2 persone hanno completato questa guida.
