Salta al contenuto principale
Nintendo WaveBird Wireless Controller Motherboard Replacement
Cosa ti serve
  1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Batteries: passo 1, immagine 1 di 2 Nintendo WaveBird Wireless Controller Motherboard Replacement, Batteries: passo 1, immagine 2 di 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Motherboard Replacement, Front Panel: passo 3, immagine 1 di 2 Nintendo WaveBird Wireless Controller Motherboard Replacement, Front Panel: passo 3, immagine 2 di 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Motherboard Replacement: passo 4, immagine 1 di 2 Nintendo WaveBird Wireless Controller Motherboard Replacement: passo 4, immagine 2 di 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: passo 5, immagine 1 di 3 Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: passo 5, immagine 2 di 3 Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller Motherboard Replacement, Motherboard: passo 6, immagine 1 di 1
    Compra
    • Using tweezers remove the three grey button pads from the motherboard.
  7. Nintendo WaveBird Wireless Controller Motherboard Replacement: passo 7, immagine 1 di 1
    • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
    • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 10-40, Amido Spring 2013 Membro di Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membri
37 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 77
Tutti i Tempi: 8,266
