Salta al contenuto principale
Nintendo 2DS Volume Slider Replacement
Cosa ti serve
  1. Nintendo 2DS Volume Slider Replacement, Volume Slider: passo 1, immagine 1 di 3 Nintendo 2DS Volume Slider Replacement, Volume Slider: passo 1, immagine 2 di 3 Nintendo 2DS Volume Slider Replacement, Volume Slider: passo 1, immagine 3 di 3
    • Turn the 2DS over so that the backside is facing upwards.
    • Identify the two Phillips #00 screws on the upper rear panel.
  2. Nintendo 2DS Volume Slider Replacement: passo 2, immagine 1 di 3 Nintendo 2DS Volume Slider Replacement: passo 2, immagine 2 di 3 Nintendo 2DS Volume Slider Replacement: passo 2, immagine 3 di 3
    • Loosen the two screws on the upper back panel using a Phillips #00 screwdriver.
    • The screws are captive and will not detach from the back panel or separate from the panel upon removal.
    • Use a spudger to pry the upper back panel off, starting at the indent at the center top of the panel.
    • Use a spudger and work your way around the perimeter to release the clips and then lift the panel off.
  3. Nintendo 2DS Volume Slider Replacement: passo 3, immagine 1 di 3 Nintendo 2DS Volume Slider Replacement: passo 3, immagine 2 di 3 Nintendo 2DS Volume Slider Replacement: passo 3, immagine 3 di 3
    • Use your finger or a spudger to lift and pull the battery outwards from the side closest to the outer edge.
  4. Nintendo 2DS Volume Slider Replacement: passo 4, immagine 1 di 3 Nintendo 2DS Volume Slider Replacement: passo 4, immagine 2 di 3 Nintendo 2DS Volume Slider Replacement: passo 4, immagine 3 di 3
    • Pull the stylus out from the middle of the left edge of the device.
    • Use a Phillips #00 screwdriver to remove ten 2.0 mm screws from the back panel.
    • Unlike the top rear panel, these screws come out, so be sure to keep them in a safe place.
  5. Nintendo 2DS Volume Slider Replacement: passo 5, immagine 1 di 3 Nintendo 2DS Volume Slider Replacement: passo 5, immagine 2 di 3 Nintendo 2DS Volume Slider Replacement: passo 5, immagine 3 di 3
    • Use a spudger to pry the back case off by working around the perimeter of the device, starting from the bottom of the 2DS.
    • Don't yank or pull the back case off because the camera ribbon is attached to the motherboard and back case and may rip or damage the cable or camera itself.
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the camera cable.
    • Use your spudger to gently slide the cable out of the connector.
    • Remove the back case.
  6. Nintendo 2DS Volume Slider Replacement: passo 6, immagine 1 di 3 Nintendo 2DS Volume Slider Replacement: passo 6, immagine 2 di 3 Nintendo 2DS Volume Slider Replacement: passo 6, immagine 3 di 3
    • Gently pry the side that holds the volume slider off of the 2DS.
  7. Nintendo 2DS Volume Slider Replacement: passo 7, immagine 1 di 3 Nintendo 2DS Volume Slider Replacement: passo 7, immagine 2 di 3 Nintendo 2DS Volume Slider Replacement: passo 7, immagine 3 di 3
    • Remove the volume slider from the sidebar housing.
Conclusione
S. Leng
Membro da: 10/24/22
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 86
Ultimi 30 Giorni: 209
Tutti i Tempi: 2,897
