Introduzione
If the blender doesn't power on, the circuit board may be damaged. This guide will show you how to replace a non-responsive circuit board.
Cosa ti serve
Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
Lift the base up to remove it.
Using the Phillips #2 screwdriver remove the 4 screws (10mm long, 5mm wide) on the circuit board.
Altre 3 persone hanno completato questa guida.
8 Commenti
Thanks for this. Where can I locate a vendor to purchase a circuit board?
Where can I get the circuit board?
Anyone had any luck on finding the circuit board to buy?
Excellent information, just need the circuit board or the schematics.
