Salta al contenuto principale
Nikon D80 Motherboard Replacement
Cosa ti serve
  1. Nikon D80 Motherboard Replacement, Main Board: passo 1, immagine 1 di 2 Nikon D80 Motherboard Replacement, Main Board: passo 1, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Motherboard Replacement: passo 2, immagine 1 di 3 Nikon D80 Motherboard Replacement: passo 2, immagine 2 di 3 Nikon D80 Motherboard Replacement: passo 2, immagine 3 di 3
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Motherboard Replacement: passo 3, immagine 1 di 3 Nikon D80 Motherboard Replacement: passo 3, immagine 2 di 3 Nikon D80 Motherboard Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Motherboard Replacement: passo 4, immagine 1 di 2 Nikon D80 Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Motherboard Replacement: passo 5, immagine 1 di 1
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Motherboard Replacement: passo 6, immagine 1 di 3 Nikon D80 Motherboard Replacement: passo 6, immagine 2 di 3 Nikon D80 Motherboard Replacement: passo 6, immagine 3 di 3
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
  7. Nikon D80 Motherboard Replacement, Motherboard: passo 7, immagine 1 di 3 Nikon D80 Motherboard Replacement, Motherboard: passo 7, immagine 2 di 3 Nikon D80 Motherboard Replacement, Motherboard: passo 7, immagine 3 di 3
    • Unscrew the three 2.3 mm screws using a Phillips #00 screwdriver.
    • Use the Phillips #00 screwdriver to unscrew the three 4.7 mm screws.
    • Gently remove the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Sara Martin
Membro da: 10/09/17
577 Reputazione
4 Guide realizzate
USF Tampa, Team S1-G1, Leahy Fall 2017 Membro di USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 47
Tutti i Tempi: 3,396
