Salta al contenuto principale
Nikon D7000 Motherboard Replacement
Cosa ti serve
  1. Nikon D7000 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Motherboard Replacement: passo 3, immagine 1 di 2 Nikon D7000 Motherboard Replacement: passo 3, immagine 2 di 2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Motherboard Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Motherboard Replacement: passo 7, immagine 1 di 1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Motherboard Replacement: passo 9, immagine 1 di 1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Motherboard Replacement: passo 11, immagine 1 di 1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Motherboard Replacement: passo 13, immagine 1 di 1
    • Carefully lift the back case off.
  14. Nikon D7000 Motherboard Replacement: passo 14, immagine 1 di 3 Nikon D7000 Motherboard Replacement: passo 14, immagine 2 di 3 Nikon D7000 Motherboard Replacement: passo 14, immagine 3 di 3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Motherboard Replacement: passo 15, immagine 1 di 2 Nikon D7000 Motherboard Replacement: passo 15, immagine 2 di 2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Motherboard Replacement: passo 16, immagine 1 di 1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Motherboard Replacement: passo 17, immagine 1 di 1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Motherboard Replacement: passo 18, immagine 1 di 1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Motherboard Replacement: passo 19, immagine 1 di 3 Nikon D7000 Motherboard Replacement: passo 19, immagine 2 di 3 Nikon D7000 Motherboard Replacement: passo 19, immagine 3 di 3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Motherboard Replacement: passo 20, immagine 1 di 2 Nikon D7000 Motherboard Replacement: passo 20, immagine 2 di 2
  21. Nikon D7000 Motherboard Replacement: passo 21, immagine 1 di 1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Motherboard Replacement: passo 22, immagine 1 di 1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Motherboard Replacement: passo 23, immagine 1 di 1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Motherboard Replacement: passo 24, immagine 1 di 1
    • Lift the motherboard off.
Conclusione
Altre 9 persone hanno completato questa guida.
Jed Chen
Membro da: 04/01/15
1.796 Reputazione
3 Guide realizzate
Cal Poly, Team 24-6, Lancaster Spring 2015 Membro di Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 Membri
5 Guide realizzate
5 Commenti
Hi thank you.
winnaingsoe - Replica
perfekt. Thank you! Had to replace the board because the GPS port was brocken.
Georges Hamlet - Replica
Hi, thanks for the detailed instructions! I just replaced my main board and the new one did not boot. The battery is charged, but the LCD shows nothing when battery is in and when the power is on. Is that a problem with the replacement main board or does it need to be programmed? I expected it to power up once the power is available.
serget - Replica
Have you resolved your issue?
Bhaskar vedula -
I get CLOCK with low battery indication . I checked internal battery health and I replaced with new battery on motherboard . Now with new battery in place I see voltage 3.12v and still camera does show CLOCK symbols with low battery. Please let me know if there is hard reset makes default configuration.
Bhaskar vedula - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 5,951
