Salta al contenuto principale
Nikon D5000 Speaker Replacement
Cosa ti serve
  1. Nikon D5000 Speaker Replacement, Back Panel: passo 1, immagine 1 di 3 Nikon D5000 Speaker Replacement, Back Panel: passo 1, immagine 2 di 3 Nikon D5000 Speaker Replacement, Back Panel: passo 1, immagine 3 di 3
    • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
    • Unscrew the eight Phillips #00 screws on the back panel:
    • Two 2.5x6mm screws above the screen.
    • One 3x6mm screw on the upper part of each side (two total; right side shown).
    • One 3x7.5mm screw on the lower part of each side (two total).
    • Two 3x4.5mm screws on the bottom.
  2. Nikon D5000 Speaker Replacement: passo 2, immagine 1 di 3 Nikon D5000 Speaker Replacement: passo 2, immagine 2 di 3 Nikon D5000 Speaker Replacement: passo 2, immagine 3 di 3
    • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
    • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
    • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
    • This procedure also applies to all of the other ribbon cables in the D5000.
    • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
  3. Nikon D5000 Speaker Replacement, Speaker: passo 3, immagine 1 di 2 Nikon D5000 Speaker Replacement, Speaker: passo 3, immagine 2 di 2
    • The speaker is mounted to the underside of the back panel. There is a a metal shield that holds it on.
    • Remove the four Phillips #00 screws securing the shield:
    • Three silver 3x4mm screws.
    • One black 3x3mm screw.
    • Remove the shield.
    • With the shield off, the navigation buttons and "Lv" button are free to move and rotate. Check alignment before replacement.
  4. Nikon D5000 Speaker Replacement: passo 4, immagine 1 di 1
    • Lift the blue tape on the ribbon cable.
    • Desolder the two leads to the speaker.
  5. Nikon D5000 Speaker Replacement: passo 5, immagine 1 di 1
    • Pry the speaker out of its cavity.
Conclusione
Jacob Rardin
Membro da: 04/14/14
1.390 Reputazione
6 Guide realizzate
Cal Poly, Team 13-28, Maness Spring 2014 Membro di Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 939
