Salta al contenuto principale
Nikon D5000 Battery Door Replacement
  1. Nikon D5000 Battery Door Replacement, Battery Door: passo 1, immagine 1 di 2 Nikon D5000 Battery Door Replacement, Battery Door: passo 1, immagine 2 di 2
    • On the bottom of the camera, pull the release tab towards the center of the camera, then pull up.
  2. Nikon D5000 Battery Door Replacement: passo 2, immagine 1 di 2 Nikon D5000 Battery Door Replacement: passo 2, immagine 2 di 2
    • Grip and hold the front end of the battery door at a 45-degree angle from the case.
    • Pop the battery door out by pulling the front tab up.
    • When reassembling, seat the rear tab in its slot before pushing the front tab back in.
Conclusione
Altre 2 persone hanno completato questa guida.
Jacob Rardin
Membro da: 04/14/14
1.390 Reputazione
6 Guide realizzate
Cal Poly, Team 13-28, Maness Spring 2014 Membro di Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 Membri
7 Guide realizzate
Un commento
My problem is the door on my Nikon D850 broke, leaving the small part with the two prongs in place, and I don’t know how to get them out to install a replacement door. Would appreciate suggestions tootswaller22@gmail.com
Harry Langdon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 82
Tutti i Tempi: 4,907
