Salta al contenuto principale
Nikon Coolpix S7000 Shutter Button Replacement
Cosa ti serve
  1. Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: passo 1, immagine 1 di 2 Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: passo 1, immagine 2 di 2
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • Screw locations.
  2. Nikon Coolpix S7000 Shutter Button Replacement: passo 2, immagine 1 di 2 Nikon Coolpix S7000 Shutter Button Replacement: passo 2, immagine 2 di 2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Shutter Button Replacement: passo 3, immagine 1 di 2 Nikon Coolpix S7000 Shutter Button Replacement: passo 3, immagine 2 di 2
    • Once the shutter button assembly is removed from the camera shell, carefully remove the black tape on the underside of the metal plate.
    • Black tape.
    • Do not discard the tape as you will reapply it when putting the shutter assembly back together.
  4. Nikon Coolpix S7000 Shutter Button Replacement: passo 4, immagine 1 di 3 Nikon Coolpix S7000 Shutter Button Replacement: passo 4, immagine 2 di 3 Nikon Coolpix S7000 Shutter Button Replacement: passo 4, immagine 3 di 3
    • Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it.
    • Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover.
    • Locations of the two screws.
    • Be very careful not to lose the two metal plate springs and the coiled spring when disassembling. A slow and steady hand will help prevent the springs from ejecting.
Conclusione
USF Tampa, Team S2-G3, Lacy Spring 2017 Membro di USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
4 Membri
10 Guide realizzate
Un commento
shutter keeps trying to open. clicks slighly and does not open
Beatrix - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 772
