Salta al contenuto principale
Nikon Coolpix S4100 LCD Screen Replacement
Cosa ti serve
  1. Nikon Coolpix S4100 LCD Screen Replacement, External Casing: passo 1, immagine 1 di 3 Nikon Coolpix S4100 LCD Screen Replacement, External Casing: passo 1, immagine 2 di 3 Nikon Coolpix S4100 LCD Screen Replacement, External Casing: passo 1, immagine 3 di 3
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
  2. Nikon Coolpix S4100 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the black casing on the back of the camera that runs around the LCD screen.
  3. Nikon Coolpix S4100 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
  4. Nikon Coolpix S4100 LCD Screen Replacement: passo 4, immagine 1 di 3 Nikon Coolpix S4100 LCD Screen Replacement: passo 4, immagine 2 di 3 Nikon Coolpix S4100 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
  5. Nikon Coolpix S4100 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
  6. Nikon Coolpix S4100 LCD Screen Replacement: passo 6, immagine 1 di 2 Nikon Coolpix S4100 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
  7. Nikon Coolpix S4100 LCD Screen Replacement: passo 7, immagine 1 di 3 Nikon Coolpix S4100 LCD Screen Replacement: passo 7, immagine 2 di 3 Nikon Coolpix S4100 LCD Screen Replacement: passo 7, immagine 3 di 3
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
  8. Nikon Coolpix S4100 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
  9. Nikon Coolpix S4100 LCD Screen Replacement: passo 9, immagine 1 di 1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
  10. Nikon Coolpix S4100 LCD Screen Replacement: passo 10, immagine 1 di 1
    • Remove the remaining side shell casing.
  11. Nikon Coolpix S4100 LCD Screen Replacement: passo 11, immagine 1 di 1
    • Remove the top shell casing.
  12. Nikon Coolpix S4100 LCD Screen Replacement, Functional Button Plate: passo 12, immagine 1 di 1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
  13. Nikon Coolpix S4100 LCD Screen Replacement: passo 13, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using precision tweezers, remove the ribbon cable that runs from the functional buttons plate to the under side of the motherboard.
  14. Nikon Coolpix S4100 LCD Screen Replacement: passo 14, immagine 1 di 1
    • Using precision tweezers, lift up the bottom of the functional buttons plate and remove the metal plate.
  15. Nikon Coolpix S4100 LCD Screen Replacement, LCD Screen: passo 15, immagine 1 di 2 Nikon Coolpix S4100 LCD Screen Replacement, LCD Screen: passo 15, immagine 2 di 2
    • Using precision tweezers, gently remove the ribbon cable running from LCD to the bottom side of the motherboard.
  16. Nikon Coolpix S4100 LCD Screen Replacement: passo 16, immagine 1 di 2 Nikon Coolpix S4100 LCD Screen Replacement: passo 16, immagine 2 di 2
    • Using precision tweezers, gently lift up on the black strip of the ZIF Connector securing the cable from the LCD to the motherboard.
    • Then, gently remove the wire by pulling the base of the ribbon cable towards the LCD screen.
    • Do not poke or destroy the cable itself. Be careful to only grab the black fold in the tweezers.
    • The black strip will fold back to reveal the cable, but remain attached to the motherboard.
  17. Nikon Coolpix S4100 LCD Screen Replacement: passo 17, immagine 1 di 2 Nikon Coolpix S4100 LCD Screen Replacement: passo 17, immagine 2 di 2
    • Remove the LCD screen from the metal mount.
Conclusione
Baylor, Team 4-2, Williams Fall 2015 Membro di Baylor, Team 4-2, Williams Fall 2015
BU-WILLIAMS-F15S4G2
4 Membri
8 Guide realizzate
Un commento
Quick question would this be similar to replacing the screen for the Nikon Coolpix S4300? I couldn't find anything to fix that specific camera.
Malakai Ashenafi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,010
