Salta al contenuto principale
Nikon Coolpix S210 Circuit Board Cover Replacement
Cosa ti serve
  1. Nikon Coolpix S210 Circuit Board Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 Circuit Board Cover Replacement: passo 2, immagine 1 di 2 Nikon Coolpix S210 Circuit Board Cover Replacement: passo 2, immagine 2 di 2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. Nikon Coolpix S210 Circuit Board Cover Replacement, Back Case: passo 3, immagine 1 di 1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 Circuit Board Cover Replacement: passo 4, immagine 1 di 1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 Circuit Board Cover Replacement: passo 5, immagine 1 di 1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 Circuit Board Cover Replacement: passo 6, immagine 1 di 2 Nikon Coolpix S210 Circuit Board Cover Replacement: passo 6, immagine 2 di 2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 Circuit Board Cover Replacement, LCD screen: passo 7, immagine 1 di 3 Nikon Coolpix S210 Circuit Board Cover Replacement, LCD screen: passo 7, immagine 2 di 3 Nikon Coolpix S210 Circuit Board Cover Replacement, LCD screen: passo 7, immagine 3 di 3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 Circuit Board Cover Replacement: passo 8, immagine 1 di 1
    • Gently remove the LCD screen.
  9. Nikon Coolpix S210 Circuit Board Cover Replacement, Circuit Board Cover: passo 9, immagine 1 di 1
    • After removing the LCD screen, unscrew the four 3.8mm screws that hold down the metal plate
    • Unscrew the 2.5mm screw next to the wrist-strap mount.
  10. Nikon Coolpix S210 Circuit Board Cover Replacement: passo 10, immagine 1 di 2 Nikon Coolpix S210 Circuit Board Cover Replacement: passo 10, immagine 2 di 2
    • Position the camera with the lens facing down and the shutter button facing you.
    • Lift the metal plate away from the camera without removing it fully. There is a ribbon attaching the edge of the plate to the camera.
    • The ribbon is being held in place by a black latch.
    • Carefully pry the spudger under the black latch and lift gently upward. The ribbon will slide out easily.
    • With the ribbon unlatched, the entire metal plate should now be detached.
Conclusione
Paul Doyle
Membro da: 01/20/11
504 Reputazione
3 Guide realizzate
Cal Poly, Team 5-17, Amido Winter 2011 Membro di Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,970
