Salta al contenuto principale
Nikon Coolpix L840 Buttons Replacement
Cosa ti serve
  1. Nikon Coolpix L840 Buttons Replacement, Motherboard: passo 1, immagine 1 di 3 Nikon Coolpix L840 Buttons Replacement, Motherboard: passo 1, immagine 2 di 3 Nikon Coolpix L840 Buttons Replacement, Motherboard: passo 1, immagine 3 di 3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Buttons Replacement: passo 2, immagine 1 di 1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Buttons Replacement: passo 3, immagine 1 di 2 Nikon Coolpix L840 Buttons Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
  4. Nikon Coolpix L840 Buttons Replacement, Buttons: passo 4, immagine 1 di 1
    • Unscrew the two, right-most, 2 mm screws with a Philips 000.
    • Unscrew the left-most, 4 mm screw with a Philips 000.
  5. Nikon Coolpix L840 Buttons Replacement: passo 5, immagine 1 di 1
    • Slide off the button panel in the marked direction.
  6. Nikon Coolpix L840 Buttons Replacement: passo 6, immagine 1 di 1
    • Flip to the front side of the button panel to access the button sensors.
Conclusione
Cal Poly, Team 1-11, Maness Spring 2016 Membro di Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Membri
10 Guide realizzate
Un commento
Where can I get a replacement board for the buttons?
rush - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,252
