Salta al contenuto principale
Nikon Coolpix E5700 Lens Piece Replacement
Cosa ti serve
  1. Nikon Coolpix E5700 Lens Piece Replacement, Battery: passo 1, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement, Battery: passo 1, immagine 2 di 2
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Nikon Coolpix E5700 Lens Piece Replacement: passo 2, immagine 1 di 1
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon Coolpix E5700 Lens Piece Replacement, Back Panel: passo 3, immagine 1 di 1
    • Turn to the bottom of the camera.
    • Remove the two Phillips screws located directly below the back monitor
  4. Nikon Coolpix E5700 Lens Piece Replacement: passo 4, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 4, immagine 2 di 2
    • Turn the camera to the side with the memory card slot and open the compartment for the CF card.
    • Remove the top two Phillips screws closest to the back panel.
  5. Nikon Coolpix E5700 Lens Piece Replacement: passo 5, immagine 1 di 1
    • Turn to the back of the camera.
    • Remove the top most Phillips screw on the back panel.
  6. Nikon Coolpix E5700 Lens Piece Replacement: passo 6, immagine 1 di 1
    • Turn to the last side of the back panel.
    • Remove the Phillips screw below the eyepiece.
    • Remove the Phillips screw located above the speaker.
  7. Nikon Coolpix E5700 Lens Piece Replacement: passo 7, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 7, immagine 2 di 2
    • Gently begin to remove the back panel.
    • Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
    Before pulling the panel. You MUST remove first de rubber bumper ( arrond the ocular piece ).
    diego - Replica
  8. Nikon Coolpix E5700 Lens Piece Replacement: passo 8, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 8, immagine 2 di 2
    • Now gently unplug the two wires at the bottom of the panel.
  9. Nikon Coolpix E5700 Lens Piece Replacement, Top Cover: passo 9, immagine 1 di 1
    • Finish pulling away the back panel.
    • Turn the camera to its non-grip side.
    • Remove the Phillips screw located above the strap holder.
    So far I have come across 3 different types of screw , here is my tip as you retract the screws use tape to stick them to a piece of A4 or strip of paper labelling them as you go
    Brian Moss - Replica
  10. Nikon Coolpix E5700 Lens Piece Replacement: passo 10, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 10, immagine 2 di 2
    • Open the CF card slot.
    • Remove the Phillips screw near the top of the camera.
  11. Nikon Coolpix E5700 Lens Piece Replacement: passo 11, immagine 1 di 1
    • Turn to the front of the camera.
    • Lift up the corner of the grip pad nearest to the flash bulb.
    • Remove the Phillips screw underneath the grip pad.
  12. Nikon Coolpix E5700 Lens Piece Replacement: passo 12, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 12, immagine 2 di 2
    • Lift up the flash bulb container.
    • Remove the two Phillips screws located near the base of the section.
  13. Nikon Coolpix E5700 Lens Piece Replacement: passo 13, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 13, immagine 2 di 2
    • Open the battery compartment.
    • Remove the Phillips screw located at the bottom of the battery compartment.
  14. Nikon Coolpix E5700 Lens Piece Replacement: passo 14, immagine 1 di 1
    • Begin to lift the top cover from the rest of the camera.
    • Be careful when doing this because many wires are connecting the top piece to the camera. Pulling too hard may pull these wires out.
  15. Nikon Coolpix E5700 Lens Piece Replacement: passo 15, immagine 1 di 1
    • In order to pull the top panel without removing the flash unit. You must remove the flash top cover, taking away the screw under the bulb (see image). then gently remove the plastic top cover. IMPORTANT: discharge the condenser as soon as possible (the flash wires are now exposed, and dangerous ).
  16. Nikon Coolpix E5700 Lens Piece Replacement: passo 16, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 16, immagine 2 di 2
    • Unplug the orange ribbon wire from the back of the camera.
    • Unplug the two blue ribbon wires from the back of the camera.
  17. Nikon Coolpix E5700 Lens Piece Replacement: passo 17, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 17, immagine 2 di 2
    • Remove the Phillips screws on both sides of the flash bulb mount.
  18. Nikon Coolpix E5700 Lens Piece Replacement: passo 18, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 18, immagine 2 di 2
    • Lift the top panel up and pull the flash bulb housing away from the rest of the top panel.
    • Note: The top panel will be difficult to separate from the flash bulb housing. Place your hands as shown in the picture and push upward with your thumb while holding the flash bulb housing stationary
  19. Nikon Coolpix E5700 Lens Piece Replacement: passo 19, immagine 1 di 1
    • Unplug the orange ribbon and the other wires and finish carefully removing the top panel.
  20. Nikon Coolpix E5700 Lens Piece Replacement, Front Cover: passo 20, immagine 1 di 1
    • Remove all four of the screws on the bottom of the camera.
  21. Nikon Coolpix E5700 Lens Piece Replacement: passo 21, immagine 1 di 1
    • Remove the two Phillips screws located underneath the CF card cover.
  22. Nikon Coolpix E5700 Lens Piece Replacement: passo 22, immagine 1 di 1
    • Remove the two screws on the left side of the camera.
  23. Nikon Coolpix E5700 Lens Piece Replacement: passo 23, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 23, immagine 2 di 2
    • Unplug the blue and grey set of wires near the top of the grip.
    • Unplug the blue ribbon wire located at the bottom-left side of the camera.
  24. Nikon Coolpix E5700 Lens Piece Replacement: passo 24, immagine 1 di 3 Nikon Coolpix E5700 Lens Piece Replacement: passo 24, immagine 2 di 3 Nikon Coolpix E5700 Lens Piece Replacement: passo 24, immagine 3 di 3
    • Remove the front cover slowly.
    • Be sure that the front cover is not attached to anything or caught on anything when pulling it away from the rest of the camera.
  25. Nikon Coolpix E5700 Lens Piece Replacement, Lens Piece: passo 25, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement, Lens Piece: passo 25, immagine 2 di 2
    • Remove the four black screws at the corners of the lens housing.
  26. Nikon Coolpix E5700 Lens Piece Replacement: passo 26, immagine 1 di 2 Nikon Coolpix E5700 Lens Piece Replacement: passo 26, immagine 2 di 2
    • Remove the lens case and the lens.
Conclusione
Altre 3 persone hanno completato questa guida.
Kyle Sitton
Membro da: 04/17/11
351 Reputazione
7 Guide realizzate
Cal Poly, Team 24-58, Amido Spring 2011 Membro di Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
4 Membri
18 Guide realizzate
1Commento della guida
bonjour,
je viens vers vous pour vous demandez OU je vais trouver les pièces pour remettre en état j'ai un Nikon Coolpix 5700 il a l'écran tout noir sur l'écran tout noir juste le paramètre de l'appareille.
je n'arrive pas a trouver le pièce sur quel cite je pourrais trouvé sais pièces
je tient beaucoup a mon appareil
merci de me renseigné cordialement
rolland - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 51
Tutti i Tempi: 6,373
