Salta al contenuto principale
Nikon Coolpix B700 Lens Assembly Replacement
Cosa ti serve
  1. Nikon Coolpix B700 Lens Assembly Replacement, Back Frame Assembly: passo 1, immagine 1 di 1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Lens Assembly Replacement: passo 2, immagine 1 di 1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Lens Assembly Replacement: passo 3, immagine 1 di 2 Nikon Coolpix B700 Lens Assembly Replacement: passo 3, immagine 2 di 2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Lens Assembly Replacement: passo 4, immagine 1 di 1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Lens Assembly Replacement: passo 5, immagine 1 di 3 Nikon Coolpix B700 Lens Assembly Replacement: passo 5, immagine 2 di 3 Nikon Coolpix B700 Lens Assembly Replacement: passo 5, immagine 3 di 3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
    Here the HDMI cover also comes off by itself.
    Tim T - Replica
  6. Nikon Coolpix B700 Lens Assembly Replacement: passo 6, immagine 1 di 1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Lens Assembly Replacement: passo 7, immagine 1 di 2 Nikon Coolpix B700 Lens Assembly Replacement: passo 7, immagine 2 di 2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
    How to check the rear part my b700 will turn ON when i disconected the 2 ribbons
    josesalgado74 - Replica
  8. Nikon Coolpix B700 Lens Assembly Replacement, Internal Bracket: passo 8, immagine 1 di 1
    • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
    • Remove the single 6mm screw.
    The screw to unscrew on the bottom left seems to not exist or is covered by a foam which is as large as the grey area around in the picture.
    Tim T - Replica
    Also from this step to the next the golden cover got removed it seems.
    Tim T - Replica
    I removed the left screw on the golden cover as well.
    Tim T - Replica
  9. Nikon Coolpix B700 Lens Assembly Replacement: passo 9, immagine 1 di 1
    • Insert the pry tool under the latch and gently lift up to remove the ribbon.
  10. Nikon Coolpix B700 Lens Assembly Replacement: passo 10, immagine 1 di 1
    • Move the ribbon out of the way to reveal the hidden screw.
    I think the revealed 4mm screw has to be removed.
    Tim T - Replica
  11. Nikon Coolpix B700 Lens Assembly Replacement: passo 11, immagine 1 di 1
    • Lift the button assembly gently to give access to remove the 4mm screw.
  12. Nikon Coolpix B700 Lens Assembly Replacement: passo 12, immagine 1 di 1
    • On the top of the camera, remove the 6mm screw.
  13. Nikon Coolpix B700 Lens Assembly Replacement: passo 13, immagine 1 di 2 Nikon Coolpix B700 Lens Assembly Replacement: passo 13, immagine 2 di 2
    • With the spudger tool gently pry off the white tap holding in the bracket.
    • Use the same tool to remove the glued-on ribbon.
  14. Nikon Coolpix B700 Lens Assembly Replacement: passo 14, immagine 1 di 2 Nikon Coolpix B700 Lens Assembly Replacement: passo 14, immagine 2 di 2
    • Gently lift up the button assembly to slide the bracket out.
  15. Nikon Coolpix B700 Lens Assembly Replacement: passo 15, immagine 1 di 2 Nikon Coolpix B700 Lens Assembly Replacement: passo 15, immagine 2 di 2
    • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
    • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
  16. Nikon Coolpix B700 Lens Assembly Replacement, Lens Assembly: passo 16, immagine 1 di 2 Nikon Coolpix B700 Lens Assembly Replacement, Lens Assembly: passo 16, immagine 2 di 2
    • Use the Phillips screwdriver to remove the four 6 mm screw that hold on the bracket housing.
    the screw driver I got drom the starter toolkit is 0.5mm too short to remove the last two screws nicely. But it works.
    Tim T - Replica
  17. Nikon Coolpix B700 Lens Assembly Replacement: passo 17, immagine 1 di 1
    • Remove the tripod mount from it's slot.
  18. Nikon Coolpix B700 Lens Assembly Replacement: passo 18, immagine 1 di 3 Nikon Coolpix B700 Lens Assembly Replacement: passo 18, immagine 2 di 3 Nikon Coolpix B700 Lens Assembly Replacement: passo 18, immagine 3 di 3
    • Now you just have to slide the lens assembly out of the housing.
    my nikon b700 camera lense is deffective and I want remove and inspect the lense, I want find what is wrong inside of the lense, I would lije fix it your guidance help me a lot opening and checking wrong contacts in my camera, but I found deffective my lense you are good teacher
    federico chavez - Replica
Conclusione
Altre 9 persone hanno completato questa guida.
2 Commenti
how to reset an objective error on B700 ? the lens is stopped in the middle of a hike
Per Benny Paulsen - Replica
how to reset an objective error? the lens is stopped in the middle of a hike
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 3,086
