Introduzione
In the event that the GPS unit of your Nike SportWatch stops picking up a signal, it may require a replacement. This guide involves opening the watch and removing the main board on the watch. A wire connects the GPS to the main board, so after the replacement is finished, soldering the wire back to the main board may be necessary.
If you don't have experience soldering, refer to our How to Solder and Desolder Connections guide. Be sure to turn the watch off before beginning this repair.
Cosa ti serve
Using a size #000 Phillips screwdriver, remove the six 5 mm screws on the back of the device.
