Salta al contenuto principale
Nextbook Premium 7SE Battery Replacement
Cosa ti serve
  1. Nextbook Premium 7SE Battery Replacement, Back Cover: passo 1, immagine 1 di 3 Nextbook Premium 7SE Battery Replacement, Back Cover: passo 1, immagine 2 di 3 Nextbook Premium 7SE Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Nextbook Premium 7SE Battery Replacement: passo 2, immagine 1 di 1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Nextbook Premium 7SE Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Remove masking tape from the battery.
  4. Nextbook Premium 7SE Battery Replacement: passo 4, immagine 1 di 3 Nextbook Premium 7SE Battery Replacement: passo 4, immagine 2 di 3 Nextbook Premium 7SE Battery Replacement: passo 4, immagine 3 di 3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Nextbook Premium 7SE Battery Replacement: passo 5, immagine 1 di 3 Nextbook Premium 7SE Battery Replacement: passo 5, immagine 2 di 3 Nextbook Premium 7SE Battery Replacement: passo 5, immagine 3 di 3
Conclusione
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
Baylor, Team 4-1, Williams Fall 2016 Membro di Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 699
