Introduzione
This guide provides the procedure for replacing the front buttons on the device. To access the front buttons, the device case needs to be opened. The process of opening the device might be intimidating at first, but the proper precautions are outlined in the guide. No device damage is expected if the guide steps are followed. For more information, refer to our troubleshooting page.
Ricambi
Nessuna parte specificata.
Before starting the disassembly, remove
The stylus
Any game cartridge
The SD card
Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
Using a spudger, separate the back panel from the front casing by gently prying around the panel.
There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
Using a spudger, lift out the battery.
Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
To more easily access this ribbon cable, flip the device so the back casing faces upwards. Gently slide the back casing forward, revealing the ribbon cable connecting to the motherboard.
Using a spudger, pry up the ZIF connector holding the ribbon cable.
Pull the ribbon towards the bottom casing and out of the connector.
Remove the two 7.5mm phillips screws using a PH000 screwdriver.
Gently flip over the circle pad. Be aware that the pad is pressed into the back of the circle pad on the front of the case. Gentle prying will be necessary to pry if from the back of the circle pad.
Be aware that there is a black plastic disc that sits between the circle pad module and the circle pad stick. During reassembly, stand the unit on end and hang the plastic disc on the circle pad module and hold the stick from the front to press them back together.
Remove the seven 3.5mm phillips screws holding down the motherboard using a PH000 screwdriver.
Lift off the rubber cover on the A, B, X, and Y buttons.
Using tweezers, life out the buttons.
Altre 4 persone hanno completato questa guida.
