Salta al contenuto principale
NeuTab N9 Motherboard Replacement
Cosa ti serve
  1. NeuTab N9 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Turn off your device before beginning these steps.
    • Insert the plastic opening tool into the seam between the screen and the back of the tablet. Move the opening tool along the seam until the back of the tablet releases.
  2. NeuTab N9 Motherboard Replacement: passo 2, immagine 1 di 1
    • Use the soldering gun to separate all soldered wires from the motherboard.
    • For a complete guide on how to solder, click here.
  3. NeuTab N9 Motherboard Replacement: passo 3, immagine 1 di 1
    • Use a spudger to carefully release the tabs on the three ZIF connectors securing the ribbon cables to the motherboard.
    • Carefully pull the ribbons out.
  4. NeuTab N9 Motherboard Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the three 1 mm screws from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 10
Tutti i Tempi: 220
