Salta al contenuto principale
NeuTab N7 Pro Speaker Replacement
Cosa ti serve
  1. NeuTab N7 Pro Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Power off your device before beginning disassembly.
    • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Speaker Replacement: passo 2, immagine 1 di 2 NeuTab N7 Pro Speaker Replacement: passo 2, immagine 2 di 2
    • The speaker is attached to the back cover of the device.
    • Hold positive and negative wires as close as possible to the speaker. Use small plastic spudger and fingers to simultaneously lift speaker from cover.
  3. NeuTab N7 Pro Speaker Replacement: passo 3, immagine 1 di 3 NeuTab N7 Pro Speaker Replacement: passo 3, immagine 2 di 3 NeuTab N7 Pro Speaker Replacement: passo 3, immagine 3 di 3
    • Use a soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
    • Be sure not to touch both the positive and negative terminal at the same time.
Conclusione
USF Tampa, Team 7-1, Cheng Spring 2016 Membro di USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 246
