Salta al contenuto principale
Netgear WGR614v9 Capacitor Replacement
Cosa ti serve
  1. Netgear WGR614v9 Capacitor Replacement, Lower Case: passo 1, immagine 1 di 1
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Capacitor Replacement: passo 2, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement: passo 2, immagine 2 di 2
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Capacitor Replacement: passo 3, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement: passo 3, immagine 2 di 2
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Capacitor Replacement: passo 4, immagine 1 di 1
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Capacitor Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Capacitor Replacement: passo 6, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement: passo 6, immagine 2 di 2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. Netgear WGR614v9 Capacitor Replacement, Capacitor: passo 7, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement, Capacitor: passo 7, immagine 2 di 2
    • Rotate the motherboard so that the top is facing up.
    • Set the motherboard on a flat clean surface.
  8. Netgear WGR614v9 Capacitor Replacement: passo 8, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement: passo 8, immagine 2 di 2
    • The capacitor can be found at the location shown.
  9. Netgear WGR614v9 Capacitor Replacement: passo 9, immagine 1 di 2 Netgear WGR614v9 Capacitor Replacement: passo 9, immagine 2 di 2
    • Rotate the motherboard so that the bottom is facing up.
    • Locate the two soldered contacts of the capacitor.
  10. Netgear WGR614v9 Capacitor Replacement: passo 10, immagine 1 di 3 Netgear WGR614v9 Capacitor Replacement: passo 10, immagine 2 di 3 Netgear WGR614v9 Capacitor Replacement: passo 10, immagine 3 di 3
    • Rotate the motherboard 180 degrees.
    • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
    • Refer to this link for proper de-soldering and soldering techniques.
    • Pull the capacitor from the other side of the circuit board once the solder is liquified.
    • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
Conclusione
Kyle Moore
Membro da: 10/03/11
95 Reputazione
1 Guida realizzata
Cal Poly, Team 21-24, Maness Fall 2011 Membro di Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Membri
11 Guide realizzate
Un commento
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,201
