Salta al contenuto principale
Nest Learning Thermostat 2nd Generation LCD Screen Replacement
Cosa ti serve
  1. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Removal from Wall: passo 1, immagine 1 di 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Removal from Wall: passo 1, immagine 2 di 2
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  2. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Open Display: passo 2, immagine 1 di 1
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
  3. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove the back of the display: passo 3, immagine 1 di 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove the back of the display: passo 3, immagine 2 di 2
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
  4. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: passo 4, immagine 1 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: passo 4, immagine 2 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the base connection ribbon cable.: passo 4, immagine 3 di 3
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
  5. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Lift battery from the base: passo 5, immagine 1 di 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Lift battery from the base: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
  6. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the battery from the motherboard: passo 6, immagine 1 di 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the battery from the motherboard: passo 6, immagine 2 di 2
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  7. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: passo 7, immagine 1 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: passo 7, immagine 2 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove battery from the display: passo 7, immagine 3 di 3
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
  8. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Locate auto-away sensor: passo 8, immagine 1 di 1
    • Locate the auto-away sensor.
  9. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screws: passo 9, immagine 1 di 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screws: passo 9, immagine 2 di 2
    • Remove the four 3mm screws with a #0 Phillips screwdriver.
    • Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
  10. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: passo 10, immagine 1 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: passo 10, immagine 2 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove auto-away sensor: passo 10, immagine 3 di 3
    • Lift the auto-away sensor from motherboard using tweezers.
    • Peel the copper foil gently from the EMI shield.
  11. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove screw from motherboard: passo 11, immagine 1 di 1
    • Remove one 4 mm screw from the motherboard using a #0 Phillips screwdriver.
  12. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove EMI shield from motherboard: passo 12, immagine 1 di 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove EMI shield from motherboard: passo 12, immagine 2 di 2
    • Remove the EMI shield from the motherboard using the plastic opening tools.
  13. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the LCD ribbon from the motherboard: passo 13, immagine 1 di 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect the LCD ribbon from the motherboard: passo 13, immagine 2 di 2
    • Unsnap the LCD ribbon from the motherboard gently using the tweezers.
  14. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: passo 14, immagine 1 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: passo 14, immagine 2 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Disconnect display from motherboard: passo 14, immagine 3 di 3
    • Locate the black tabs that hold the display to the motherboard.
    • Push the black tabs gently away from the motherboard using the plastic opening tools.
  15. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove from motherboard: passo 15, immagine 1 di 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove from motherboard: passo 15, immagine 2 di 2
    • Pull the face display gently away from the motherboard.
  16. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: passo 16, immagine 1 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: passo 16, immagine 2 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove bottom of display frame: passo 16, immagine 3 di 3
    • The front of the glass display and plastic frame is held together by only light adhesive.
    • Push the crescent shape bottom of the display away from the plastic frame using the plastic opening tools.
  17. Nest Learning Thermostat 2nd Generation LCD Screen Replacement: passo 17, immagine 1 di 1
    • Pry the front glass and plastic frame apart gently using the plastic opening tools.
  18. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove LCD screen from plastic frame: passo 18, immagine 1 di 2 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Remove LCD screen from plastic frame: passo 18, immagine 2 di 2
    • Pry the LCD screen gently from the plastic frame using the plastic opening tools.
  19. Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: passo 19, immagine 1 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: passo 19, immagine 2 di 3 Nest Learning Thermostat 2nd Generation LCD Screen Replacement, Separate LCD from frame: passo 19, immagine 3 di 3
    • Pull the LCD screen away from the plastic frame gently using your fingers.
Conclusione
Altre 8 persone hanno completato questa guida.
Justin Curry
Membro da: 09/23/14
264 Reputazione
2 Guide realizzate
USF Tampa, Team 11-5, Blackwell Fall 2014 Membro di USF Tampa, Team 11-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G5
5 Membri
12 Guide realizzate
5Commenti sulla guida
Please could you say the type of LCD screen? Or present detailed photo of rear side?
vladvys - Replica
Yes, this is a guide for replacing the LCD. I'd like to know what LCD to order. Thanks.
kylegoetz - Replica
Thank you for providing this tutorial. My dog, not making this up, knocked my nest off the wall. Where can I purchase the replacement green itself and the plastic opening tools you used throughout the repair? This will be my first time on something like this, but with your guide I should have a decent shot at not screwing it up.
erick.starke - Replica
Skip step 12. There is no reason to remove the EMI shield.
richardrobison - Replica
Where can you get the replacement lcd screen for gen 2 nest learning thermostat?
Stan Griff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 117
Tutti i Tempi: 16,201
