Salta al contenuto principale
Nest Cam Wi-Fi Cable Replacement
Cosa ti serve
  1. Nest Cam Wi-Fi Cable Replacement, Wi-Fi Cable: passo 1, immagine 1 di 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Wi-Fi Cable Replacement: passo 2, immagine 1 di 3 Nest Cam Wi-Fi Cable Replacement: passo 2, immagine 2 di 3 Nest Cam Wi-Fi Cable Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Wi-Fi Cable Replacement: passo 3, immagine 1 di 3 Nest Cam Wi-Fi Cable Replacement: passo 3, immagine 2 di 3 Nest Cam Wi-Fi Cable Replacement: passo 3, immagine 3 di 3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Wi-Fi Cable Replacement: passo 4, immagine 1 di 1
    • Using a soldering iron, melt away the base of the Wi-Fi cable until it can be removed. Use this guild for assistance with soldering.
    • Ensure when you solder the new cable back on that all connector ends are positioned correctly.
Conclusione
Jade Weiss
Membro da: 02/24/16
662 Reputazione
3 Guide realizzate
USF Tampa, Team 1-1, Leahy Spring 2016 Membro di USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Membri
10 Guide realizzate
2 Commenti
I have broken the cable attached to Nest camera. Can you get replacement or repair the lead? Hope i haven't got to buy a new camera
Kerrie Davies - Replica
I have broken lead attached to Nest camera. Can i get a replacement or repair it? Hope i havent got to buy a new camera.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 4,331
