Salta al contenuto principale
Motorola syn1654A Headphone Speaker Replacement
Cosa ti serve
  1. Motorola syn1654A Headphone Speaker Replacement, Headphone Speaker: passo 1, immagine 1 di 1
    • Make sure the headphones are off and unplugged from any devices.
    • Remove leather headphone cushion by pulling edge towards middle of headphone.
    • It should slip off the device.
  2. Motorola syn1654A Headphone Speaker Replacement: passo 2, immagine 1 di 1
    • Carefully peel back foam pad to prevent tearing.
    • It is glued at both the top and bottom.
  3. Motorola syn1654A Headphone Speaker Replacement: passo 3, immagine 1 di 1
    • Use the T6 torx screwdriver to remove the three screws holding the speaker in place.
    • To avoid stripping screws, be sure to use the right screw bit oriented perpendicular to the face of the screw.
  4. Motorola syn1654A Headphone Speaker Replacement: passo 4, immagine 1 di 1
    • With the speaker removed from the speaker module, clip the black and white wires on the back of the speaker, as shown.
    • Solder wires onto corresponding pads of replacement speaker.
    • For soldering see the ifixit soldering guide: Come saldare e dissaldare componenti elettrici
Conclusione
John Ware
Membro da: 02/24/14
325 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 414
