Salta al contenuto principale
Motorola RAZR V3i Battery Replacement
Cosa ti serve
  1. Motorola RAZR V3i Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Motorola RAZR V3i Battery Replacement: passo 2, immagine 1 di 3 Motorola RAZR V3i Battery Replacement: passo 2, immagine 2 di 3 Motorola RAZR V3i Battery Replacement: passo 2, immagine 3 di 3
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  3. Motorola RAZR V3i Battery Replacement: passo 3, immagine 1 di 3 Motorola RAZR V3i Battery Replacement: passo 3, immagine 2 di 3 Motorola RAZR V3i Battery Replacement: passo 3, immagine 3 di 3
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
Linea Traguardo
Altre 5 persone hanno completato questa guida.
Nigel
Membro da: 09/06/11
133 Reputazione
2 Guide realizzate
Cuesta, Team 1-5, Zipperian Fall 2011 Membro di Cuesta, Team 1-5, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G5
1 Membro
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 60
Tutti i Tempi: 7,328
