Salta al contenuto principale
Strumenti
Nessun attrezzo specificato.
Parti
  1. Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Kits di riparazione iPhone X
    Garanzia finita? Non preoccuparti, abbiamo la soluzione.
    Acquista ora
    Acquista ora
  3. Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge. Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely. The flat edge of a credit card or other flat object will also work.
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  4. Remove the battery by pushing down on it from the top while gently pulling it outwards. Be careful not to use too much force as the battery retaining tab could be damaged. Be careful not to use too much force as the battery retaining tab could be damaged.
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Nigel
Membro da: 06/09/2011
130 Reputazione
2 Guide realizzate
Cuesta, Team 1-5, Zipperian Fall 2011 Membro di Cuesta, Team 1-5, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G5
1 Membro
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 4,838
