Introduzione
Use this guide to replace the rear facing camera.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Cosa ti serve
Apply a heated iOpener to the lower glass panel on the back of the phone for five minutes.
Slide the spudger along the side of the phone until you get to the clip securing the display to the rear case.
With the spudger right next to the clip, carefully twist the spudger to pry the display away from the rear case and release the clip.
Tilt the top right corner of the display down to disengage one of the tabs that secure the top of the display.
Tilt the other corner down next, to disengage the other tab.
Lift the right edge of the display to hinge the phone open like a book, no more than 45°.
Gently lift the display enough to clear the clip from the edge of the rear case, maintaining the 45º angle.
Rest the display on the table behind the phone and open to 90º to allow access to the display cable.
Insert a spudger underneath the left edge of the camera and pry up to loosen it from the motherboard.
Use tweezers to remove the Kapton tape from the camera's ZIF connector.
Use flat end of spudger to lift the locking flap.
Gently pull the camera's flex cable straight out from its ZIF connector.
Remove the camera.
