Introduzione
When the Motorola G7 Play, models XT1952-3 and XT1952-2, no longer charges, it could be due to a failing charging port. This replacement guide provides efficient steps to get the device working again. If replacing the charging port doesn’t fix the issue, attempt to replace the battery with this guide.
Cosa ti serve
Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
Altre 7 persone hanno completato questa guida.
Un commento
Xt1952-4 is the same. Replaced the charge port due to microphone failing.
