Introduzione
This guide will walk you through the process of replacing the volume buttons in a Motorola Moto G4 Plus phone.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
Cosa ti serve
Insert a fingernail or a spudger into the notch on bottom edge of the phone near the charging port.
Pry the back cover away from the body of the phone.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using tweezers, lift up the black silicon piece connecting the motherboard to the front casing.
Using tweezers, remove the red and black cable connecting the motherboard to the front casing.
Using tweezers, remove the volume buttons.
Altre 3 persone hanno completato questa guida.
