Introduzione
This guide will walk you through the process of replacing a faulty headphone jack in a Motorola Moto G4 Plus phone.
Parti
Insert a fingernail or a spudger into the notch on bottom edge of the phone near the charging port.
Pry the back cover away from the body of the phone.
Remove the battery.
Using tweezers, lift up the black silicon piece connecting the motherboard to the front casing.
Using tweezers, remove the red and black cable connecting the motherboard to the front casing.
Using tweezers, lift up the black silicon piece covering the audio jack.
Altre 6 persone hanno completato questa guida.
Un commento
I accidentally broke the headphone jack ribbon cable socket off of the motherboard - its a very small 3 socket ZIF connector that wasn’t attached very good. Now I have no display - I’m wondering if the headphone jack has something to do with it? I would think breaking that connector would only affect the headphone jack.
