Salta al contenuto principale
Motorola Moto G Stylus (2021) Rear Case Replacement
Cosa ti serve
  1. Motorola Moto G Stylus (2021) Rear Case Replacement, Rear Case: passo 1, immagine 1 di 3 Motorola Moto G Stylus (2021) Rear Case Replacement, Rear Case: passo 1, immagine 2 di 3 Motorola Moto G Stylus (2021) Rear Case Replacement, Rear Case: passo 1, immagine 3 di 3
    • Push a SIM tray ejector into the hole.
    • Remove the SIM card and tray.
  2. Motorola Moto G Stylus (2021) Rear Case Replacement: passo 2, immagine 1 di 2 Motorola Moto G Stylus (2021) Rear Case Replacement: passo 2, immagine 2 di 2
    • Before you begin, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your phone and disconnect the charger and any peripheries before beginning disassembly.
    • Lay the phone face down.
    • Heat an iOpener and apply it to the rear case.
    • Alternatively, use a hair dryer to heat the rear case until it's almost too hot to touch.
  3. Motorola Moto G Stylus (2021) Rear Case Replacement: passo 3, immagine 1 di 2 Motorola Moto G Stylus (2021) Rear Case Replacement: passo 3, immagine 2 di 2
    • Insert an opening tool into the seam between the rear case and chassis.
    • Once you create a gap, insert an opening pick a couple of millimeters into the gap.
    • Slide the opening pick around the entire perimeter to sever the adhesive that secures the rear case.
    • If you feel excessive resistance, reheat the problem area(s).
    • Remove the rear case.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor
Membro da: 03/29/22
12.088 Reputazione
64 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.418 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 28
